Use this procedure to configure the Fabric Attach assignment time-out.
Configure the FA assignment time-out:
Switch:1>en Switch:1#conf t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#fa assignment-timeout 50
Verify the configuration:
Switch:1(config)#show fa
Fabric Attach Configuration
FA Service : enabled
FA Element Type : server
FA Assignment Timeout : 50
FA Discovery Timeout : 240
FA Provision Mode : spbm
Variable definitions
The following table defines parameters for the fa assignment-timeout command.
Variable |
Value |
<45–480> |
Specifies the Fabric Attach assignment time-out in seconds. The default value is 240 seconds. |
